noise from clutch pedal
hey everytime i push my clutch in it makes a squeeking noise like i can shift fine but i just make a squeeking noise that is annoying as hell.... what oculd that be i wiped away the rod underneath there and some of the springs and got a look of black **** off of it but its still making the squeeking noise... could it be something inside or what...
car is a 94 del sol si
Re: noise from clutch pedal (wspcivic)
crawl under you dash and grease all the pivot points on the cluch pedal, thats all, what you wiped off was grease, and since the grease will not penetrate those areas your probabibly going to have to take some things apart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wspcivic »</TD></TR><TR><TD CLASS="quote">throw out bearing or bad CMC</TD></TR></TABLE>
have the same thing . didnt get it fixed yet but most people said its the throw out bearing
Re: noise from clutch pedal (SaveTheSohc)
I have it too, its throwout bearing. You have to take off your whole tranny to fix it so I just deal with the noise
