main relay help
main relay help
ok i have a problem. i have a 95 civic hatch cx and the harness was hacked. so i got my hands on a 95 integra GSR harness with everything. fuse boxes, modules, relays, dash harness, cluster, engine harness, almost everything.
problem. main relay is cut off. i didnt know it at the time of purchase. i looked in a 94 ls in the junk yard and couldnt find the plug to replace it . i have also bought a chiltons book for 84-95 honda civics, and 94-00 acura integras. i also have tried to search the net for wiring diagrams on the relay.
im trying to take the main relay and plug off the civic harness and put it on the GSR harness. but theres a different number of wires and colors. so thats why i need the diagrams. the GSR harness is already installed in the car and already paid for. i dont want to take it back out and put in a civic harness. i mean im going a b-series swap and a full GSR dash swap in the car so if i can work out the bugs it will be fine.
any suggestions or anyone with the relay plug and relay from a GSR that they want to sell let me know.
theyre the same relay, there should be 10 wires total, 3 of the pins have 2 wires, heres a diagram
1 2
7 8
1 - Yellow w/ white (to the battery)
2 - black (ground) should have 2 wires
3 - Yellow w/ black (to ECU) has 2 wires
5 - Black w/ yellow (to ignition)
6 - Blue w/ white (to starter switch) has 2 wires
7 - Yellow w/ green (to fuel pump)
8 - Green w/ yellow (to ECU)
im pretty sure the ones with 2 wires are the ones i said have 2 but if not youll be able to tell which ones have 2 when you look at them. This diagrams for a civic but im pretty sure the two are the same since both civics and tegs have the same main relay
1 2
7 8
mudandrox
06-03-2016 10:10 AM
PatrickGSR94
09-08-2003 10:58 PM
