map sensor wiring
map sensor wiring
hi to start off im from the uk ! im am doing a engine conversion on my eg civic, it used to have a d16z6 engine in and im converting it to a b16a2 engine
on the d16z6 engine over here the map sensor is on the throttle body and wired in through the main engine harness ! but on the b16a2 for the eg it is mounted on the firewall with a seperate wiring harness, now i didnt get the map sensor or wiring with the engine so can i use the map sensor off my d16z6 ? also how do i wire the map sensor in ? which wires goto where etc. ?
Re: map sensor wiring (seanclark)
attatch the map sensor from the D16 with a vacuum hose to one of the vacuum ports on the B16 throttle body. Use your D16 wiring harness and plug it in.
Mikes2000civicsi
06-04-2011 09:02 PM
92ehatch
10-15-2006 06:16 AM
SOHCEK-Turbo
10-16-2003 09:42 PM
