y8 head setup in a y5 even better?..
i was running a y5 head (vtec-e) uptil now.. then i bought a rebuilt y8 head on ebay... a friend tells me, to make my swap even faster i should put the y8 cam and rocker arms in the y5 head?... is this true? and whats the reasoning behind this?..
Re: y8 head setup in a y5 even better?.. (Sir_LagaLot)
uhh i doubt this will be compatible as the y5 and the y8 have diffrent versions of vtec....y5 is the HX and y8 is just Vtec.
Re: y8 head setup in a y5 even better?.. (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sir_LagaLot »</TD></TR><TR><TD CLASS="quote"> a friend tells me, to make my swap even faster i should put the y8 cam and rocker arms in the y5 head</TD></TR></TABLE>
well your friend needs to learn about the Y5 head .. and by reading this you and him both can
https://honda-tech.com/zerothread?id=753403
also how does that head look bc i saw the head on ebay and even thought of buying it
Re: y8 head setup in a y5 even better?.. (haveaniceday)
thought so.. thanks for the help guys..
about the head..well, it looked pretty neat in the pictures.. and i believe the seller el_neives or something is selling another one just like it.. standard rebuilt job... resurfaced to avoid warpage, pressure tested for cracks, new valve seals and a 3 angle valve job.. i do believe 300 $ was a bit steep though...
does a 3 angle valve job do much in terms of performance when it comes to a y8 head?..cause i heard most y8 heads and others already come with a 3 angle valve job from the factory.... *shrugs..
the head is in ny at the moment, friend should be bringing it with him.
crooked muffler
03-23-2003 11:20 AM
