headgasket help
* B A N N E D *
headgasket help
dose anyone have the plans to take the head off a singel cam to change the headgasket? its off a d15b2
Re: headgasket help (Just Joey)
Remove exhaust manifold, timing belt, lines and wires. drain coolant.
Undo head bolts. Clean everything with thinner and scrape if need be (must be spotless) put on new gasket. torque the bolts. reconnect everything.
Walk away.
or hopfully drive away
Walk away.
* B A N N E D *
Re: headgasket help (s_vares)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s_vares »</TD></TR><TR><TD CLASS="quote">Remove exhaust manifold, timing belt, lines and wires. drain coolant.
Walk away.
or hopfully drive away</TD></TR></TABLE>
torque what bolts? what how much...
u are my helper 2day
Walk away.
your best bet is to get a chilton manual.. unless someone is kind enough to post pages from it on here. there is alot more to it then described in that post. such as how to remove the timing belt.. removing intake mani.. the sequence in removing the head studs, and proper torque values.. BTW you SHOULD get new head studs to replace the old ones.. but most people dont. gl buddy.
SOHCLUDE6
01-12-2012 06:35 PM
Duck*
02-08-2006 09:14 PM
tremor86
07-04-2004 04:22 AM
tremor86
07-03-2004 03:14 PM
