Just cant figure it out Need HELP ASAP
Headgasket went out so I got it fixed. Then the water pump went out got that fixed. Valve cover was leaking fixed that also. Now it's over heating I changed the thermostat. I flushed the radiator put i did not use a hose I used a gallon water jug. So could it be the radiator? I also put radiator stop leak in before i found out it was the water pump. I found some of the stop leak stuff in my extra radiator fluid thing. The fans cut on but I think they come on late it's heating up and they still don't come one till it's almost too late. I'm lost so any help would be help full thanks.
Re: Just cant figure it out Need HELP ASAP (88sleeperx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88sleeperx »</TD></TR><TR><TD CLASS="quote">. I flushed the radiator put i did not use a hose I used a gallon water jug. So could it be the radiator? </TD></TR></TABLE>What do u mean by this? When I flush my car I take the plastic screw thing off the bottom of the radiator, and I take the big bolt out of the side of the block and hook the water hose to my heater hose and let it run for a cpl mins, then im good to go
I don't have a hose I took the screw out of the bottem and out about four gallons though. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 »</TD></TR><TR><TD CLASS="quote">What do u mean by this? When I flush my car I take the plastic screw thing off the bottom of the radiator, and I take the big bolt out of the side of the block and hook the water hose to my heater hose and let it run for a cpl mins, then im good to go </TD></TR></TABLE> ?What bolt?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88sleeperx »</TD></TR><TR><TD CLASS="quote">I don't have a hose I took the screw out of the bottem and out about four gallons though. ?What bolt?</TD></TR></TABLE>the bolt thets underneith the header, I think its a 17or 19mm
slikz714
07-12-2006 03:40 AM
