question bout rear disc on eg hatch
I've heard they won't. I've always been told that the eg model civic's shared similar chassis' with 94/01 Integra's..although I don't really see how it's possible.
But it could happen.
Re: (cherryhatch00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherryhatch00 »</TD></TR><TR><TD CLASS="quote">I've heard they won't. I've always been told that the eg model civic's shared similar chassis' with 94/01 Integra's..although I don't really see how it's possible.
But it could happen.</TD></TR></TABLE>
i know that 94-01 integra will work for sure but im sure bout a DA integra
Yes plain and simple. They are on my hatch. I had the hardest time getting a straight answer out of anyone on this site, so I finally said screw and spent a saturday replacing the bushings in the DA trailing arms and swapped everything out. Got an alignment just to make sure that I hadn't changed the geometery, and the work like a charm.
Pretty cool that 3 noobs posted in the same thread one after another , and no one started E thugin!!
Re: (p00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p00n »</TD></TR><TR><TD CLASS="quote">Yes plain and simple. They are on my hatch. I had the hardest time getting a straight answer out of anyone on this site, so I finally said screw and spent a saturday replacing the bushings in the DA trailing arms and swapped everything out. Got an alignment just to make sure that I hadn't changed the geometery, and the work like a charm.</TD></TR></TABLE>
so its just straight bolt on like a newer integra?
Re: (eg6sir88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir88 »</TD></TR><TR><TD CLASS="quote">do you suggest an alignment afterwards?? and u callin me a n00b??</TD></TR></TABLE> No.... not you, the other 3 with noob avatars. Yes, anytime you do suspension parts, if you can afford it, it's always in your best judgement to get an alignment. Their are some DIY alignments that you can do to save some money. PM and I'll explain or search in the RoadRacing/Autocross forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc dis »</TD></TR><TR><TD CLASS="quote">
so its just straight bolt on like a newer integra?</TD></TR></TABLE>
Yep, you guessed it, When I get home from work, I'll post an excellent link for rear disc swap.
Re: (p00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p00n »</TD></TR><TR><TD CLASS="quote">Yep, you guessed it, When I get home from work, I'll post an excellent link for rear disc swap.</TD></TR></TABLE>
thanks bro i found some really cheap but wasnt sure if i should buy them
Cian Mcloughlin
07-12-2012 01:43 PM
cool_junk
08-20-2007 06:41 PM
