New dizzy... will not fit? why not?
i have read on the net and honda-tech that a d series is a d series..... that a dizzy no matter if it's vtec or not will fit on none and vice-versa.......
i have a 1.6 vtec and i ordered a 1.5 dizzy..... it goes in the hole but the bolt holes does not line up..... it's off some... so why? should i just drill the holes out or does it not fit for a reason? it's faceing the right way just the way i took the old one out... ... all wires plug up correctly...
what could be the problem??
Re: New dizzy... will not fit? why not? (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 »</TD></TR><TR><TD CLASS="quote">vtec and non vtec dizzys are different.</TD></TR></TABLE>
well damn... could i drill out just a lil and it will fit......??? all the wires hook up correctly...... will it run right????
NASIOC.com
Re: New dizzy... will not fit? why not? (SpOoLiNg CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpOoLiNg CiViC »</TD></TR><TR><TD CLASS="quote">well damn... could i drill out just a lil and it will fit......??? all the wires hook up correctly...... will it run right????</TD></TR></TABLE>
Dont ******* half *** it, trust me i broke a cam trying to do something like that... your car will run like **** aswell...
Re: New dizzy... will not fit? why not? (Otherguy)
Yea I wouldn't half-*** anything as important as ignition and timing. Try to return it or sell it again or something I dunno.
Re: New dizzy... will not fit? why not? (bart2546)
y7 and y8 are the same dist. All the fins are the same as well. The only difference is the housing mounting points. If you cant put it in all the way try rotating the fins 180* and try again.
just took both apart and put the new one in the old vtec housing... car start but runs like a v8 ...lops like i have a stage 90 cam in it... lol..... i get check engine code 22... vtec pressure...... but that is not causing problem... i put new spark plugs and new 10.2 spark plug wires.... all are fireing..... i belive i bent a valve!.
so new vtec head will be put on in a few days when i can locate one...
most all D series dizzies are the same except the d16z6 and the d15z1. (92-95 vtec)
Of course there are differences in harness for ODB1 and 2 etc. You need a d16z6 specific dizzy. (d16z6 and d15z1 are the same bolt pattern)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy »</TD></TR><TR><TD CLASS="quote">why dont you go take it to a mech, because you prob fucked up the timming ;P</TD></TR></TABLE> i 2nd that motion
DA chosen 1
Honda Fit
15
05-25-2006 01:59 PM
Honda Type R
04-08-2006 05:31 AM
