cluster problem, blown fuse?
i was hooking up my oil gauges to power and the lights stopped working on the cluster, theres no beeping when u turn th lights on without a key either. When the ignition goes on everything works but the background lights. Checked fuses but seem fine, any ideas?
Re: cluster problem, blown fuse? (silverboost)
When you were routing your own wiring and such around, did you happen to pull a main plug out? Do the actual instruments work? I mean do you have fuel/temp/tach/speed-o functions? I'd look into the plugs on the back of the cluster. Also, is it just the instrument panel that is not lighting or are your heater controls/radio not lighting up either? Check any fuses relating to the instrument panel with a fine tooth comb.
timntam
02-03-2006 11:10 AM
mrbsponge
12-31-2003 03:31 PM
serboy00
12-20-2003 06:49 PM
