replacing headlights
i received a set of jdm headlights for Christmas and was wondering if anyone had a walk trough or any tips on installing them. Am i going to hav to remove the bumper? anything that i should look out for?
Re: replacing headlights (silverSOHC)
whats your car ( make, model, year)?
I've done this job on EG , withOut removing the front bumper ( i just remove the corners screws and bolts, and "stuff" the headlights in there)
Installed properly, No problem at all
tricky ( try not to scratch the paint, used masking-tape, or some sort of thick tape ), but its do-able , saves time.
Modified by sleeper101 at 9:59 AM 12/30/2006
If you ( i was once) never done any bumper removal /replacement,
I suggest that you better remove the bumper completely ( do it right, or not at all)
then, after you got the hang of it, u can do my trick ( previous post above)
so you won't have unnecessary headache
Re: replacing headlights (sleeper101)
ok thanks... so just remove the bumper and all the screws are visible... doesnt sound very tricky... thanks alot guys
There are 2 bolts under the bumper and 1 bolt at each end of the wing. Pop out the 5 popper screws holding the grille in and gently pull the bumper with the grille out.
Azn Mug3N (01 em2)
Honda Civic (2001 - 2005)
05-19-2007 05:38 PM
Soda Popinski
02-05-2005 10:52 PM
Jurassic Four
13
06-04-2004 03:14 PM
