Check Engine Light Question???
How do I reset the light? I fixed my O2 Sesor probelm and now need to turn off the light...Isn't there away of doing?
Thanks in Advanced!
Thanks in Advanced!
HT White Ops
1. Remove negative battery cable
2. Wait 5 minutes
3. Replace Negative battery cable
Or, if you want it erased, then drive to Checker/Schucks/Kragen/Autozone/PepBoys/O'Reily's/ Whatever and have then run the code, and then clear it.
2. Wait 5 minutes
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">1. Remove negative battery cable
2. Wait 5 minutes
Or, if you want it erased, then drive to Checker/Schucks/Kragen/Autozone/PepBoys/O'Reily's/ Whatever and have then run the code, and then clear it.</TD></TR></TABLE>
I see too much time in that as you actually have to get a rachet out.
Pull the "backup fuse" in your fuse box, it's the ECU fuse, then wait 5 minutes (I think haynes says you only need to wait 20 seconds, but whatever) and plug the **** back in.
This is the fuse box in your engine bay...not the under dash one.
2. Wait 5 minutes
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Being as my sticker is missing, and I know exactly where my ratchet is .... </TD></TR></TABLE>
Ah, I suppose that's a good argument.
Though it's generally pretty rare that the sticker is gone on the fuse box in the engine bay - the under-dash, sure, but usually not the one in the engine due to pple generally keeping their engine dry and such, they don't "accidently kick it" and such. - I hear ya tho, I just find the fuse easier to pull (b/c it's right there) then to unbolt the terminal, pull it off, wait, put it back on, then tighten it :-\.
