CEL CODE????
Old Oct 10, 2007 | 05:29 PM
Midori Green's Avatar
Default CEL CODE????
ok so i put the scan tool at my shop to my car and it read catalytic bank 1..... should i replace the O2 or the cat itself??????????
Old Oct 10, 2007 | 05:44 PM
Default Re: CEL CODE???? (Midori Green)
???? my vote is on O2 but i wanna hear some opinions im sure somebody has had this code
Old Oct 10, 2007 | 06:00 PM
by the way the engine is a 00 d16y7
Modified by Midori Green at 7:14 PM 10/10/2007
Old Oct 10, 2007 | 06:21 PM
Old Oct 10, 2007 | 06:49 PM
WhiteEkCivic's Avatar
I would try the o2 sensor first. They are alot cheaper than a cat.
Old Oct 10, 2007 | 07:31 PM
Default Re: CEL CODE???? (WhiteEkCivic)
yea but i also have an extra cat that i picked up off an 07 civic si and i just happened to might need it now and roughly how much to O2 sensors go for???
Old Oct 10, 2007 | 08:35 PM
will do....
Old Oct 11, 2007 | 11:48 AM
Old Oct 11, 2007 | 05:37 PM
It all depends where you get it from. I have seen them go for as low as $20 all the way up to $60+.
Old Oct 11, 2007 | 06:09 PM
yea thats tru thanks bro i'll be buyin it this weekend
Old Oct 11, 2007 | 06:32 PM
hondamark35's Avatar
is it a stock y7? not super familiar with the 07 si cat, but the stock y7 cat is built into the exhaust manifold. if you plan on using the other cat you will at the least need to get an ebay header or y8 manifold (or any d-series without a built-in cat)
by the way what was the 'P' code you read?
Old Oct 11, 2007 | 06:42 PM
Default Re: CEL CODE???? (hondamark35)
i already have aftermarket full exhaust including headers so i dont have a pre cat i only have the regular cat but yess the motor is stock i dont understand what p code is
Modified by Midori Green at 8:01 PM 10/11/2007
Old Oct 13, 2007 | 05:37 PM
A "P Code" is the code that your scan tool is going to give you... For example.. My civic is throwing a P1337 and a P1508.... What was the code u were throwing?
Crazyxc2448
Mar 25, 2010 03:56 PM
2k1 SSM GSR
Oct 22, 2004 11:30 AM
Two_K Si
Oct 13, 2004 08:32 PM
civicsicko
Jul 16, 2004 10:10 PM
hondachick81
Oct 6, 2001 10:05 AM
