battery light on all the time?
hello,
i have looked through countless threads, but i could not find an answer. when i try to start my car, 1998 civic with a lsvtec, it will not crank over. the battery light stays on all the time when it is in ignition 2. i have ran a obd2 scanner and it just says failed. i am running and 2000si engine harness with a p2t ecu. i have also had the battery starter and alternator tested and they all came up great.
thanks a lot
bill!
thanks a lot
bill!
Re: battery light on all the time? (wbaldwin_86)
Wow, I wish I could help more people on here but I just don't really know anything about swaps, and that seems to be what everyone does. Honda put a great engine in my car for me!
Re: battery light on all the time? (USDMCIVICHATCH)
yeah i bought the car from a insurance company as a theft recovery, and i had to get a new car wiring harness...
damn .... i cant help you either ... but if u cant find answer bring it to a shop let them find the problem and take it home and fix it . always work for me and dont spend to much money .
Unceasing Measure
If the OBD scanner comes back with a "failed" result, that suggests you wired something up incorrectly. It only takes one misplaced wire to screw up a lot of things.
If you're confident in your wiring abilities, it might be a problem with the gauge cluster, but with the scanner issue I wouldn't bet on it.
when does yr car not crank over got to do with yr charging light? it will be on anyway when yr engine is not running.
Re: battery light on all the time? (spoon_ek9)
oh wow i need to be more observative... thanks for the input. now i just need to find out why my car isnt cranking over
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wbaldwin_86 »</TD></TR><TR><TD CLASS="quote">hello,
thanks a lot
bill!</TD></TR></TABLE>
what do you meen it will not crank over? does it spin and just not start or does it just click and nothing happens at all? also be a little more specific as to what you have done to the car so far
thanks a lot
Bad_dude
01-25-2011 07:10 PM
