clutch problems d16y7
Well I just did the front brake's on my car yesterday and after I finished everything was fine.So we go to jack and grab something to eat,leaving jack my clutch pedal is really hard.And just to put it into perspective am 195lb and I've lifted weights before and it is pretty difficult for me to push in the pedal let alone hold it to the floor.So we swing by autozone on the way back and pick up some brake fluid so we can bleed the slave cylinder.After we bleed the slave cylinder same thing,the pedal is still hard.I don't have a clue what it could be,any help or suggestions would be appreciated.
Re: (hifonics)
sounds like a bad slave cylinder man, im not positive but thats what i would diag. at work if i got it...pretty cheap you just have to bench bleed them like a master cylinder...unless you know someone that thinks differently on what it could be
Re: (hifonics)
it sounds alot like the cylinder not the slave itself...usually when a slave is shot it squeeks like a bad belt when your off the clutch totally and you said yours doesnt do that, the only other thing it could be is the slave cylinder, since it regulates the clutch pressure and the amount of free play that it has, just replace it, bleed it, and go, no clutch adjustment at all, just on cable trannys...
gsr1289
08-22-2006 07:11 PM
Xander teh Grate!
11-09-2003 05:32 PM
