Prelude Discs on EG?
So am i right is thinking early Prelude discs are 4x100 so would fit the Civic hubs?
Wanna roll with Prelude calipers hence the question
Thanks
Thanks
look at the part numbers or go to a junk yard and find a prelude and a 88-00 civic and swap out calipers and see if it works... won't cost you a dime that way!
Re: (p00n)
yup, prelude conversion is pretty common,
you need
prelude vtec calipers
prelude 282mm disc redrilled to 4x100
then you either need 2mm spacer behind the rotor to center caliper or mill 2mm of mounting points of the caliper. Both work well.
thats it your done
you need
thats it your done
