Engine Problem...Car stumbles/bogs out
Here is the problem:
When driving my car, between 1500-3000 rpms under 20% pressure or more on the gas pedal the car hesitates/bogs out. If I hold the gas down the car loses all power and backfires at times. I have replaced the dist cap rotor and spark plugs. This seemed to work as a temporary solution but the problem is back. The car is not giving me any cels. Any ideas on the problem?
Re: Engine Problem...Car stumbles/bogs out (cjk95delsolsi)
try a different oxygen sensor.. my car was doing the same thing except only between cold and fully warmed up...
a voltmeter reads volts btw
0% throttle =~ 0.45 - 0.50 volts
WOT =~ 4.45 - 4.55 volts
btw there should be no flat spots when you open the throttle, i.e. the reading should not jump around at any point and should progress linearly up to 4.5 volts. if you have any flat spots or erroneous readings in between, get a new tps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjk95delsolsi »</TD></TR><TR><TD CLASS="quote">do you know what amps or watts it shoud read?</TD></TR></TABLE>
does the OP have a CEL?
I dont have a cel.
Another thing is if the car is sitting at idle and i rev it up with full throttle and hold it the car will bog down and die as if it lost all power.
Re: (cjk95delsolsi)
did you check you fuel filter or pressure regulator?? sounds like it's clogging somewhere and it slowly looses gas or maybe even air.
I have been doing some research on here and I have found several people with similiar problems and people are saying it the ignitor. Do you think this could be it?
bowdown201
02-12-2009 11:01 AM
crnimacak
01-19-2006 04:59 PM
