weird sound
weird sound
i have a d16z6 in my 95 del sol and i have a skunk2 intake manifold and an intake on it and during certain acceleration or throttle movement i get this really high pitched sound.... not the intake this isnt my first car... im thinking maybe the gasket between the throttle body and intake manifold could be leaking? any other suggestions would be great
Re: weird sound (marecco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marecco »</TD></TR><TR><TD CLASS="quote">i have a d16z6 in my 95 del sol and i have a skunk2 intake manifold and an intake on it and during certain acceleration or throttle movement i get this really high pitched sound.... not the intake this isnt my first car... im thinking maybe the gasket between the throttle body and intake manifold could be leaking? any other suggestions would be great </TD></TR></TABLE>
somone mentioned the air flowing over the TB making a whistling noise. Just a thought, my car makes that noise as well as my friends gsr with a skunk 2 IM
Re: (marecco)
Are there any vacuum leaks when it idles? If not then I'm inclined to say that if you hear something only when there is a throttle delta, then it's not a gasket leaking or else you would be aware of it all the time.
im pretty sure there isnt it stays pretty steady at idle maybe just a little fluctuation here and there. but i think the gasket may have been like broken sorta on one side when it got installed so could this slight brake make that sound?
Re: (marecco)
I highly doubt it. Air is going to move where it's easiest to do so, in other words, if your throttle is open then air is going to be rushing in through your intake arm and past your throttle plate. It's not going to be seeping in from a slight break in the gasket. You will notice a leaky gasket on idle, not when throttle is open.
Integacivic
07-31-2004 01:59 PM
