best ecu for b16a2
best ecu for b16a2
ok so am swaping a 2000 b16a2 into my hatch whats the best ecu for it that i can get at a junkyard or sumthing because they say that p28 is good but think about it the ecu redline is 7ish right when you can make mor power till 8000rpms?
Re: best ecu for b16a2 (tigueremalo)
chipped p28 is the way to go if its obd1. for making the redline at 8200k for stock b16 when it is chipped the b16 basemap will be used and it will automatically fix and move things up... also if you get it tuned you can get more detailed.
Re: (em1_fox)
if you use the proper ECU P2T, its way cheaper, can be had for ~$50, no conversion harness needed, and you will pass emissions
or you can spend $200+ on a chipped P28 that will make you run filthy stinken rich
Revolution2zz
08-10-2006 07:52 AM
