Knocking coming from the valves.
Ok so after starting the car and letting it sit for a few minutes you can hear a slight knocking noice. Upon inspection i realized it was coming from inside my valve covers. What do yall think it could be. And will it cause any serious damage??? Thanks for the info.
Re: Knocking coming from the valves. (Dav94Lx)
if its coming from your valve cover then your valve guides might be going bad and the valve has a little to much play and slaps when the valve face tries to seat....does it go away once the car is fully warm????
Re: Knocking coming from the valves. (spray_bombed)
you usually aren't going to "hear" valves going bad..
yeah, definately adjust valves before considering anything else as the cause for the noise. it is true that a properly adjusted and tuned honda will tick (it should sound like a girl tapping her fingernails on a counter or some hard surface.)
pityocamptes
26
03-25-2016 10:23 AM
