Bottom end Turbo build d16y8
With the money it seems a turbo set-up is in my budget range. I did a lot of d16 turbo build research, so i have most of that basic parts needed down down. One site even had a list of guys running 7-12 psi on totally facorty internals. Theres a 1,000 and 1 kits on ebay so im gonna look for the best deal.
t3/t4 turbo
oil line kit
38mm wastegate
downpipe
stainless manifold
intercooler
bov
turbotimer
larger injectors?
sparkplugs?
hondata?(fuelmanagment)
can i keep my ecu?
as far as my engine compents go my car has been maintained well. I just did the throttlebody/intakemanifold gaskets, and the head gasket. The oil is changed consistantly and my ignition is up to par.
I was gonna leave the head factory and work the bottom end???
any ideas?
t3/t4 turbo
oil line kit
38mm wastegate
downpipe
stainless manifold
intercooler
bov
turbotimer
larger injectors?
sparkplugs?
can i keep my ecu?
any ideas?
Re: Bottom end Turbo build d16y8 (6gencoupe97429)
To be honest. . .you can actually keep the stock internals with the turbo set-up runing no more than like 8psi prof. tuned. . .but i wouldnt recomend buying an ebay set-up. . .there manifolds crack very easily. . .
I'd recommend rebuilding the bottom end! I just turbo'd my D16Y8 (about 6 psi with a Greddy kit) with proper tuning, etc. and toasted my crankshaft (too much compression causing detonation and pushing all the oil out of the bearings...not fun) I picked up Vitara pistons, H-beam rods, all new bearings for just over $600. I'm in the process of boring the cylinders 20 over right now...
best of luck with your build!
I don't see why people spend so much money on building the engine when you can have a good tune instead and make sure its reliable. I'd say just get the necessary elements for slapping a turbo kit together and get it tuned, and make sure you use head studs.
im hench irl
Re: Bottom end Turbo build d16y8 (zc92hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zc92hatch »</TD></TR><TR><TD CLASS="quote">To be honest. . .you can actually keep the stock internals with the turbo set-up runing no more than like 8psi prof. tuned. . .but i wouldnt recomend buying an ebay set-up. . .there manifolds crack very easily. . .</TD></TR></TABLE>
You can keep your stock internals. D-series internals are more reliable than most people think. Check this out. 400hp 26 psi yadi yadi yada. https://honda-tech.com/zerothread/2104408 AWD.
im hench irl
Re: (Ron454321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron454321 »</TD></TR><TR><TD CLASS="quote">I don't see why people spend so much money on building the engine when you can have a good tune instead and make sure its reliable. I'd say just get the necessary elements for slapping a turbo kit together and get it tuned, and make sure you use head studs.</TD></TR></TABLE>
I second the headstuds though.
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redz_EX »</TD></TR><TR><TD CLASS="quote">I'd recommend rebuilding the bottom end! I just turbo'd my D16Y8 (about 6 psi with a Greddy kit) with proper tuning, etc. and toasted my crankshaft (too much compression causing detonation and pushing all the oil out of the bearings...not fun) I picked up Vitara pistons, H-beam rods, all new bearings for just over $600. I'm in the process of boring the cylinders 20 over right now...
best of luck with your build!</TD></TR></TABLE>
detonation isnt going to cause your bearings to go dry. you had other issues.
Unceasing Measure
Re: (drtysohc)
Stock everything with about 130k on the clock, my buddy's making 223whp witha stock greddy kit on his Y8. A good tune will get you there. He's been at 212+ for over 30k miles.
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Stock everything with about 130k on the clock, my buddy's making 223whp witha stock greddy kit on his Y8. A good tune will get you there. He's been at 212+ for over 30k miles.</TD></TR></TABLE> I had a y7 that held together at over 200 whp for 9 months, and it finally went when I over revved it combined with a 16psi boost spike
