Y8 Vtec Pressure sensor questions...
1 Post
Hopefully this forum will be more helpful...
I have a d16y8 head I'm putting on my d15 and my vtec oil pressure sensor is broken. I'd like not to have to spend more money so Im wondering if I can bypass the sensor and not use it at all?
Has anyone done this with the y8? I've heard of people with JDM b motors needing to do this when using the USDM ECUs, so I would think it would work the same way, but can anyone confirm this for me? Please I really need help on this.
Thanks!
Thanks!
Re: Y8 Vtec Pressure sensor questions... (Ahknodd)
yea you bypass it the exact same way people do when they use JDM motors, tap the pressure switch signal into the VTEC output
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotroddb8r »</TD></TR><TR><TD CLASS="quote">just get a jdm ecu, cuz there is no way you can bypass that sensor, what car are you doing tha swap?</TD></TR></TABLE>
you ******* newbs are getting worse and worse
edit: your better off buying a new pressure switch for ~$20 and fix the problem instead of just covering it up
1 Post
Re: Y8 Vtec Pressure sensor questions... (sicones)
Thanks for the help... finally a good strait answer!
I don't want to cover it up, but the sensor I have is broke and I haven't been able to find a cheap sensor and plug for the life of me. I really don't want to spend 50 bucks for either, so I was looking for a way to make this all work. I know it's just a saftey anyway.
But again, thanks.
But again, thanks.
Jakester9500
01-15-2007 08:23 PM
