valve clearance on minime swap with stage 2 cam?
hey guys, I was wondering if I'll have enough valve clearance with a comp stage 2 cam in a minime swap. its a d15b8 block (out of a cx) with a z6 head. any help would be much appreciate. thanks!
-Lars
-Lars
Re: valve clearance on minime swap with stage 2 cam? (circuitEG6)
either way i dont know the duration or lift on those cams, call up the tech support they will be able to tell you
Re: (h22aBB4)
just call the manufacturer tech support line and they would be able to tell you the exact specs...its an important clearance, but usually stage 2 cams are pretty serious on oem pistons clearance wise...
alexthegrinch
35
07-10-2009 03:20 PM
blackhatchb20
06-14-2006 07:03 AM
