1999 Civic Wont Turn (solved)
My 99 civic MT will not start. I can push start and it will run fine. Battery is good and starter is less than a year old. I read somewhere it could be the clutch pedal stop pad. I did find a small cone shaped piece on my floorboard. Could this be the problem? If so, what exactly is the purpose of this piece and where exactly does it go?
re: 1999 Civic Wont Turn (solved)
The problem was determined to be the plastic stop pad for the clutch interlock switch. I was able to JB weld a rubber stopper in place in lieu of a new grommet because I have no idea how I would access it well enough to properly install it.
