Electircal wiring and fuses; 12V cigarette lighter
So my 12V outlet in my del Sol is acting up, won't charge my phone and barely lights a cigarette. I've read somewhere that you can bump the fuse up, say from the 15 amp to a 20 amp, because older car lighters were only designed to light cigs, not charge phones and stuff. Is there any truth to this? If so, any tips on rewiring/replacing the cigarette lighter?
I'm putting in a headlight warning in the fuse box, so i figured I could get this knocked out at the same time. Found the headlamp buzzer instructions no prob, but I can't find the one for the lighter.
https://honda-tech.com/forums/honda-...stall-3133840/
Old Fart
Re: Electircal wiring and fuses; 12V cigarette lighter
No truth to that at all, changing the fuse will not supply any more power to a lighter.
If a lighter is not getting hot enough it is because it is releasing too soon or the lighter itself is N/G.
Try this, hold the lighter in place after it pops out for a few min. longer, if it then heats up enough adjust the bimetal "holders" at bottom of lighter housing, or just replace the lighter housing.
As a phone charger needs far less power to work, changing the fuse will not make any diff. there either.
The charger problem is more then likely a "fit/contact" problem, the charger lighter adapter is not making proper contact with either the pos.(+) or neg.(-) inside the lighter housing, you need to test the output of the charger to see what is missing.
Never replace a fuse with a bigger one, it can result in your car burning to the ground. 94
Old Fart
Yep, that will solve the lighter issue, but may not solve the charger issue, as that is more of a problem with the lighter plug adapter for the charger. 94
