Gasket question
Gasket question
So I have oil in the 2 Spark plug tubes. I'm going to replace the seals but do I have to replace the valve cover gasket as well. Are gaskets seals only good for the initial seal?
My oil pan has a dorman rubber plug because I think the rapid oil change guys probably stripped the original plug. I was thinking of re-tapping it but doing it with the oil pan off. Again would I replace the oil pan gasket of I remounted the same oil pan.
Re: Gasket question
You can probably get away with using the valve cover gasket again if it's fairly new and in good condition. I believe Honda sells the VC gasket in a kit with the spark plug gaskets and it's not that expensive. So why not just replace it?
As far as the oil pan gasket, I think it's a one time use.
eH.
eH.
5Point7Liter
03-12-2008 09:30 AM
thudreem
10-20-2006 08:43 AM
teler86
14
05-18-2006 05:18 AM
