type-r swaybar for civics 92-95
i bought a type-r swaybar 23mm bushings and d-brackets from jdmland.com,, but does anyone know it bolts on,it doesnt seem to fit with the d-brackets.also anyone know where i can see pics of this part,if so thanks ,if not still -thanks.
Re: (YELLOW_DUCK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YELLOW_DUCK »</TD></TR><TR><TD CLASS="quote">don't put that on untill you have and ASR or a BECKS rear subframe brace</TD></TR></TABLE>
It's BEAKS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike_C »</TD></TR><TR><TD CLASS="quote">you need to have endlinks and lcas that support endlinks (92-95 ex and si, 94-01 integra).</TD></TR></TABLE>
These LCAs will work but I chose to go aftermarket. It will bling it up under there and "lighten" the weight. Also the endlinks provided should match up perfectly (they did for me in my EG Sedan) as do the D-Brackets.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo »</TD></TR><TR><TD CLASS="quote">yeah, an asr brace would be nice if you dont like tearing out your subframe.</TD></TR></TABLE>
And this my friend is a must. You don't want to replace a subframe
Note to the OP: I am pretty sure the ITR swaybar is 22mm...
It's BEAKS
Re: (YELLOW_DUCK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YELLOW_DUCK »</TD></TR><TR><TD CLASS="quote">96 spec ITR came with a 22mm rear sway bar
98 spec ITR came with a 23mm rear sway bar
My bad
My bad
Del Soouulll
05-01-2007 09:35 AM
