Car Shuts Off When Giving Gas HELP PLZ
WAS UP Honda Tech I JUST GOT A 97 COUPE WITH A OBD-1 V-TEC RESON BEING IS BECAUSE THE OLD OWNER BLOW THE OBD-2 MOTOR THAT WAS IN IT OK SO NOW WHEN I TURN THE KEY THE CAR STARTS FINE IDELS GOOD AND ALL BUT THE MIN YOU GIVE IT GAS IT CUTS OFF ANY IDEA WHAT IT COD BE AND CAN IT BE FIXED ?
What Do I Do : ????????????
Cut Or Heated Springs Wich Ones Better ?
Re: Car Shuts Off When Giving Gas HELP PLZ (jnunez08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnunez08 »</TD></TR><TR><TD CLASS="quote">WAS UP Honda Tech I JUST GOT A 97 COUPE WITH A OBD-1 V-TEC RESON BEING IS BECAUSE THE OLD OWNER BLOW THE OBD-2 MOTOR THAT WAS IN IT OK SO NOW WHEN I TURN THE KEY THE CAR STARTS FINE IDELS GOOD AND ALL BUT THE MIN YOU GIVE IT GAS IT CUTS OFF ANY IDEA WHAT IT COD BE AND CAN IT BE FIXED ?
Check engine light on? Does it go off after a few seconds of turning the key to on position? If not check the code. Did you change out the oil pump to obd2?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnunez08 »</TD></TR><TR><TD CLASS="quote">Cut Or Heated Springs Wich Ones Better ?</TD></TR></TABLE>
Neither both ghetto, $30 ebay coilovers are better.
Re: (jnunez08)
top of this forum check the faq's. Here's alink because i ball like that.
https://honda-tech.com/zerothread/1901557
Re: (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs »</TD></TR><TR><TD CLASS="quote">top of this forum check the faq's. Here's alink because i ball like that.
https://honda-tech.com/zerothread/1901557</TD></TR></TABLE>
thxs
thxs
UCNTCME
03-28-2008 01:31 PM
dem0nk1d
12-17-2006 07:14 PM
