problem: 95 civic wheel wobble/shake
i was driving the other day and some guy in another car noticed my passenger front wheel was wobbling. So at the stop light he told me i figured no biggie my lugnuts where probably loose so when i got home i went to tighten them and they were all tight so i take the wheel off to see if i notice a problem the axle was tightened and the hub was tight also. I have no idea whats going on do you guys have any suggestion that can help me out ?
Re: problem: 95 civic wheel wobble/shake (EJ2-Fluffy)
Also check your wheel bearing and perhaps your wheel is out of balance?
Any vibrations in the steering wheel? Or and pulls while braking?
Re: problem: 95 civic wheel wobble/shake (Somnambulist)
no it cant be the wheel bearing it dont make the noise and the rims and tires are brand new and were balanced i think it could be the tie rod i am able to move the tire side to side even when the other side of the car is on the ground and when i drive if you stick your head out the window you can see the wheel look like its wobbling
09egkid
08-06-2010 02:54 PM
