will LS axies fit GSR tranny?
i just got a GSR tranny for my EG6 with a LS in it and i was worunding if the LS axies fit the GSR tranny just want to now if i have to buy GSR axies
Re: will LS axies fit GSR tranny? (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs »</TD></TR><TR><TD CLASS="quote">same ****.</TD></TR></TABLE>
yea, IIRC all B-series axles are the same *Even automatic axles as thats what I'm using in my LS swap*
Re: will LS axies fit GSR tranny? (Dasfinc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc »</TD></TR><TR><TD CLASS="quote">
yea, IIRC all B-series axles are the same *Even automatic axles as thats what I'm using in my LS swap*</TD></TR></TABLE>
Except 90-93 driver side da axle is different from 94+ b series axle. Just reuse your old int. shaft and axles you'll be fine.
Except 90-93 driver side da axle is different from 94+ b series axle. Just reuse your old int. shaft and axles you'll be fine.</TD></TR></TABLE>
Forgot about that, thats the axle you use in a EF for a b-series swap right?
Forgot about that, thats the axle you use in a EF for a b-series swap right?</TD></TR></TABLE>
they work in all civics and integra's you just have to have a da int shaft and change out the driver side axle seal to a da axle seal. Lengths are almost identical. But yeah alot of people use them in ef swaps because they usually use OBD0 engines and trannies that come with the da style int shaft.
DA int shafts suck ***** though, ever had an axle that wouln't come out of that damn hole? Sometimes its permanently in there. Hence why honda switched to the dc style int shaft.
EK_Rider253
02-09-2007 09:45 PM
superstreetb16
07-31-2005 04:26 PM
slowem1si
02-26-2004 05:15 PM
