Oil Pan
Old 03-05-2008, 11:25 PM
SpoonFedEj8's Avatar
Default Turbo: Oil Pan Problems
I'm having issues with my install of my turbo kit on a d16y8. The problem being that the down pipe is coming in contact with my oil pan. Did I get the wrong pipe or has anyone experienced this before on a Ej8. WTF. Please no flaming just trying to finish this install. This is the only problem I am having. Any help would be great. Thanks.
Modified by SpoonFedEj8 at 12:38 AM 3/6/2008
Old 03-05-2008, 11:35 PM
saywhat's Avatar
Default Re: Oil Pan (SpoonFedEj8)
Where did you get the DP? every set up is different. If it were me, I would heat it up and bend it or cut and weld.
Old 03-06-2008, 12:24 AM
Default Re: Oil Pan (saywhat)
Rev Hard 2.5" Down pipe . Thats what I was thinking of. If I was to upgrade the oil pan to maybe a moroso pan would I be able to run it without fabrication or would i still run into the same problem. At least then I wouldn't have to drill out my own oil return line. Opinions on that. Thanks for that option it was actually going to be my go to resort if I cant figure out anything else.
Old 03-06-2008, 12:47 AM
Going to bed bump. Need some help asap. I know fab. but any other options. Thanks again.
Old 03-06-2008, 07:43 AM
saywhat's Avatar
I am not too familiar with the Moroso pans, but it seems like a long way to go and some $$ to get the DP to clear the oil pan. How much space do you need? I guess you could always try putting a little dent with a hammer in the pan, just make sure the pick up still has clearance down there. I don't know what else to tell ya. Good luck
Old 03-06-2008, 07:48 AM
1992Si's Avatar
A small dent in the pipe may be easier too.
Old 03-06-2008, 07:50 AM
saywhat's Avatar
Default Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">A small dent in the pipe may be easier too.</TD></TR></TABLE>
True.
Fully_Built
02-06-2008 09:21 AM
EJ1 wilcox
11
02-16-2005 08:57 AM
SiRkid
05-11-2003 10:22 PM
B20-T
02-24-2003 10:44 PM
MCP486
01-19-2003 09:33 AM
Quick Reply: Oil Pan
