Cleaning headlight plugs?...
When replacing my head light bulb on my 00 civic. I noticed a lot of gunk build up on the headlight plug itself. And once I put on the replacement bulbs. The driver side headlight wont turn on. The passenger side works fine, the gunk is like brown almost like peanut butter consistency.
Anything I can do to clean it, cause I think it's preventing electrical connection to the bulb. But it will turn on when I use the high beam. I made sure the replacement bulb was fine because I switched it to the passenger side and both work. Any ideas?
Re: Cleaning headlight plugs?... (2tonecivic21)
I just got some eletrical cleaner, still didn't help. The low beam still doesnt turn on, and bulbs are brand new.
Re: Cleaning headlight plugs?... (VTECth1s)
Sometimes with all that build up, once the old light is taken out, you break what's referred to as the "super-secret mechano-electro-chemical bond," and the plug will never work again. Seriously, what I'd do (unless it's a fuse) is probably just pull one from the junk yard and splice it in.
Re: Cleaning headlight plugs?... (prplhrtcivic)
I think thats what happened, cause even the new bulbs I got don't work. Damn!
How bad is it to run off high beams? The bulbs could eventually burn out right?
im gonna clean the gunk out the plug wire and see if that works cuz only the driver side is dirty and only the driver side doesnt work
problem has been fixed!!..
I checked the low beam fuses under the dash. And wow they both were blown. I replaced them and now its working again!
Well I'd still like to know cuz mine does the same thing and I gotta get out and tap the headlight everyday for it to turn on. Its all brown as well. I check the wires and none seemed to be loose and fuses are ok
gold_ef
10-20-2006 02:43 PM
Mark Murda
09-17-2004 11:55 AM
