throttle body and tps
1 Post
is it possible to set the tps on a throttle body without installing it to the car first?i got a blox tb and tps i want to take it somewhere to get preset since im not understanding how you set it thanks..
Re: throttle body and tps (miguel329)
u can install tps on the throttle body first without installing it to the car but u will need to do the tps adjustment with a multimeter after all the sensors and power sources are connected.
crazyguy is right. Throttle and TPS have to be installed, and everything must be plugged, so you can calibrate the TPS. Its not difficult at all, if you have a multimeter or can ger a hold of one you will be able to calibrate it EASILY in a few minutes.
Oh and. . . search some more next time. Searching for TPS has like a million results with the same explanation over and over, this is the one I used, I hope it helps you too. Good luck!
https://honda-tech.com/zerothread?id=2193100
