another problem need suggestions
ok guys, I've posted about this before, but i'm about to sit down tonight and take a look at what all could possibly be a problem so give me ideas. when i start driving, my car is bogging down really really bad. I'm not sure that describes how bad, it's pretty horrible. mostly on acceleration too. i used to be able to top out around 110mph, now max is like closer to 90. when i accelerate it feels like someone is jerking their foot on and off the gas. Tonight I am going to take the cat off and see if it runs better. thing is, it barely idles poorly at all so i doubt it's the cat. any ideas? I know i have a very very minor compression leak, but it's not enough to affect it on this scale i don't think.
Here is what i've replaced and know is not the problem:
new sparkplugs
new wires
new grounds
new rotor and cap
new fuel injectors
new sparkplugs
new wires
new grounds
new rotor and cap
new fuel injectors
Re: another problem need suggestions (austinkli)
try to clean iacv, check spark plug wires firing order, and when was last time u replace fuel filter and inspect timing belt, see if there is a teeth off or tming belt is damanged and old ?
Re: another problem need suggestions (RonJ@HT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT »</TD></TR><TR><TD CLASS="quote">Is the CEL ON?
You might want to check whether the ignition timing is set to specification.</TD></TR></TABLE>
car wont idel or drive that rough even ignition timing is off
Re: another problem need suggestions (crazyguy)
sorry, ignition timing is fine. spark plug wires firing order is correct, fuel filter is brand new. so far i plan on checking the cat and timing. crazy guy, i'm going to clean the iacv anyway just cause i have seen that you know your **** on here and i respect your ideas, but i doubt that would make it bog down at 65 mph in 4th gear. Also, i think that would make it idle very poorly and as i said, it idles a little rough, but it's not that bad.
If the cat and timing belt turn out to be fine, other possible causes worth considering are a faulty MAP sensor, TDC/CRANK/CYL sensor, or fuel pressure regulator.
S2k Hybrid
12
04-24-2007 09:41 PM
