injector wires??
Re: injector wires?? (95JDM)
they should only be able to go on one way if its a stock harness, otherwise check any other honda and just go by the wire colors from cyl 1 to cyl 4.
unless the harness has been cut open from its tape and loom it should be self explanitory wich plug goes to wich injector. with the harness on the engine the section that goes on the intake mani. by the injectors the plugs on the harness should be in the same order as the injectors. the plug closest to the driver side is injector #1,next in line is #2, next is #3, leaving #4, closest to the pass. side. #1 brn/yel-blk #2 rd/yel-blk #3 blu/yel-blk #4 yel/yel-blk
