Fitting a D-series Exhaust on an LS swap
Did my research and did not come up with anything, I recently dropped a full LS swap in my 92 cx hatch and would basically like to just "bolt an exhaust up" Do I need to just buy an LS integra cat?
Re: Fitting a D-series Exhaust on an LS swap
I could be wrong but I think you need the header that matches the block, b-series, d-series, k series, but you use the exhaust for the car itself.
here is my problem, i've done an ls swap before in my coupe(d16z6 before I swapped)And put the LS in, and there was about a 4 inch gap...I don't know if LS cats are longer...
even if u got an ls cat itd still wouldnt line up. just use the LS manifold/header and whatever cat u have and have a shop do a $40 job to weld on an extension and flange so then you can just bolt it on.
LOVEthatDC2
05-30-2009 10:10 PM
LS94tegra
07-24-2008 12:46 AM
