Stripped crank pulley bolt
Is there any options left for me if I stripped the crank pulley bolt? I just got my cheater pipe and crank pulley removal tool, first time I tried it it stripped
Re: Stripped crank pulley bolt
Ouch.. If there are any threads left in the hole a machine shop may be able to re-thread it. If not.. then they can bore it out a little and put a steel sleeve to match the bolt. They will need the bolt that goes in it to match up the steel sleeve. I did this with the tensioner pulley bolt, cost about $50. Good luck!
holly ****. Buy a new crankshaft or Block lol. i did this and noone could fix mine so i welded my pulley lol. it worked for 4 months and up to aweek ago it fell off so im changing my block out cuz of that **** good luck.
the thread is stipped on my crankshaft does any know the thread count so i can use a tap or dye so i can re-thread it
the bolt itself is fine just the thread where the pulley bolt goes it stripped it wont torque at all
