P75 or PR4 ECU???
P75 or PR4 ECU???
Is there any difference between these two ECUs, fuel map, redline, etc...I have a p75 in my LS swapped civic (B18B1) and just obtained a pr4. As far as I know the p75 is from 1994-1995 tegs and pr4 is from 1996-200?. I just wanted to know which one's better or if they're both the same.
Re: P75 or PR4 ECU???
Use the P75. There's no reason to put an ecu that is a different OBD than your car, you'd need to buy a conversion harness to plug the other one in anyways.
1994, 2000, acura, civic, difference, ecu, fuel, hondatech, indentification, ls, map, p75, p75pr4ecuintoanaccord, pr4, whats
