ignition switch and push start help please
how are ppl wiring up push starts? are they just turning key to number 2 position and running the push button from the white battery wire to the blk/wht starter wire? because if so, honda didnt design it to work that way. when you go from pos 2 to pos 3 the accessory wire wht/blk, and the run wire yel, are turned off and the starter wire blk/wht is engaged.....
so pretty much if you run your push start like i first asked, turn to pos2 and run your switch from wht to blk/wht, is anyone having any problems or is it all good and can you tell me why honda wants to disengage the yel wire when you start and then re-engage to run?
Arseezy
01-21-2011 07:27 AM
