head gaskets?
Re: head gaskets?
Thats what i have been noticing, its not a horrible amount, but when i run it, as soon as you shift some white smoke comes out, and i just started noticing my coolant resevoir getting a little lower
Re: head gaskets?
i assumed it probably was the head gasket starting to go but i wanted to get a few other opinions first. so say that that is wats wrong, will it be ok for about two weeks will i can get the parts? as long as i keep coolant on it
Re: head gaskets?
The trick when you search is to select to search in Title only and select the forum in which you want to search. Here, I've done that for you: https://honda-tech.com/search.php?searchid=1108867
Re: head gaskets?
You should be alright along as you don't get on it, and go on long trips cause you can warp your head if the motor heats up to much which happens when you have an blown head gasket. If you do drive it and one day you come out and there is a tone of white smoke coming out the tail pipe i would drive then until you get it fixed.
D3vin
14
03-14-2010 08:41 PM
BOOSTEDgreeneg
07-08-2004 01:34 PM
