HELP: drivability issue!
Old Mar 27, 2009 | 05:49 PM
EM1203's Avatar
Default HELP: drivability issue!
My setup:
00' SI, 96' JDM GSR, ported&polished head, comlete new valve train, buddy club specIII cams. JDM TYPER pistons STD, lightened flywheel. All block components completely balanced, professionally done by machinist. Blox intake manifold/header/FPR. Stock injectors. Ive used the following ecus- US/JDM GSR , hondata, stock SI
Problem: While driving engine cuts out, no matter how much gas I give, no response, then all of a sudden engine cut back in(about 2-3seconds of cut out). Its a harsh cut out and cut back in. This problem was going on before i rebuilt my motor this winter. I checked pretty much everything i could think of; heres my list of what i checked.
TPS sensor-good all in spec.
MAP- good
Timing- right on
Cap/ Rotor/ Wires-new
Ignitor- good
jumper harness- good brand new
coil- good
fuel pressure is good even when engine cuts out.44psi
new timing belt
cam timing is good/ ignition timing.
I checked all wiring, tried switching out ecu's nothing changes. All vaccum hoses are good; im running out of things to check, anyone with that has some ideas that could help would be very helpful! Thanks.
Old Mar 27, 2009 | 05:52 PM
instructor74's Avatar
Default Re: HELP: drivability issue!
sounds a bit like a bad igniton switch
Old Mar 27, 2009 | 05:59 PM
EM1203's Avatar
yeah I didnt mention but the engine stays running but no reponse at all.
Old Mar 27, 2009 | 06:08 PM
Former User's Avatar
Intermittently bad coil or ICM in the distributor? Have friend who will let you borrow a compatible distributor?
Old Mar 27, 2009 | 06:17 PM
EM1203's Avatar
yeah that was my next step, but ive swapped known good coils and nothing changes
Old Mar 27, 2009 | 06:22 PM
Try also swapping the ICM and, if no satisfaction, then the distributor. Are all of the distributor wire connections clean and tight?
Old Mar 27, 2009 | 06:25 PM
EM1203's Avatar
yeah everything is perfect, my brother has the same dizzy, ill try using his and see what happens.
Jasebring
Jun 19, 2023 07:53 PM
xotic_crx
Engine Management and Tuning
24
Nov 1, 2013 08:51 AM
xtp
Sep 11, 2013 10:19 AM
recon-da
Jun 16, 2005 09:13 PM
