96 civic wont start
Old 12-11-2009, 07:28 PM
civic91sief's Avatar
Icon6 96 civic wont start
ok, today my car wouldn't start after i let it sit all day, i checked the main relay, fuses in engine compartment and inside of car, next i checked to see if i get spark to the distributor and no spark, which wire do i test on the plug that goes to the distributor to check if its getting power?
Old 12-11-2009, 07:29 PM
eghcivic95's Avatar
Default Re: 96 civic wont start
have you check you grounds?
Old 12-11-2009, 07:48 PM
Former User's Avatar
Check the Blk/Yel wire attached to the coil inside the distributor. You should neasure battery voltage with the key in ON(II).
Does the fuel pump prime for 2 seconds when the key is turned to ON(II)?
Any CEL codes?
Old 12-11-2009, 07:55 PM
leondx's Avatar
listen for fuel pump priming. its prolly quite simple your overlooking. does it turnover? does it run for a split sec and die? details...
Old 12-11-2009, 08:33 PM
Jimster480's Avatar
Any CEL codes?
x2
Does the car even have power? Its possible its a weak or dieing battery, this happened to my car yesterday.
ToolJunkie21
06-22-2016 06:25 PM
CaseyB
11-16-2012 06:03 AM
Steveojonez2112
07-24-2012 03:55 PM
standbackimapro
07-27-2009 03:38 AM
Quick Reply: 96 civic wont start
