steering wheel
Re: steering wheel
The EG steering column is smaller then the S2k and the only way to make it fit is if you can make a cone shaped washer to slip over your stock steering column to compensate for the size difference but that is not exactly safe.
Or you can change out the entire column from a 96+ civic to your EG and you can use the S2k wheel.
