Need help car wont start
i got a 94 honda civic hatchback with a h22a motor swap
my car wont crank after i got a new walbro fuel pump .... is it beacuse of the cold weather????
need help asap
need help asap
Re: Need help car wont start
Need a bit more info then that sir.
If you installed the pump and it does not work then my first guess is that you did not measure how far the pump goes down and or did not install the filter correctly then on-top of all this your tank was low as well which cause the pump not being able to suck fuel.
After you provide with more info then people can help you better.
1. Do you hear the fuel pump priming?
2. Do you have fuel?
3. Was the car running before?
yes my car was running before until the fuel pump stop working and the walbro was already assemble im guessing it the fuse then
Check your grounds and battery cables and try getting a jump start. If it starts right up when jumped, the battery could be bad.
LOL... now we get the rest of the story, lol.. Yes ur battery should be at 12-12.5 when the engine isn't running and 13.7-14.5 when it is running.
kk now it crank but it doesnt fire like when you start it up i hear like a clicking from somewhere around my steering column ... ... and one more thing i think i burn my harness where the steering column is because my tail light wouldnt turn on so i use a 100amp fuse to make it work but i guess my wire wasnt strong enough...
cuz when i signal to the left it dont work but my right one does and my headlight stay on without the fuse in it or even when it no turn on
need help
need help
