b16 in eg9 ?
b16 in eg9 ?
i have a b16 with a GS-R head but the motor is obd2 and the car is obd1 will everything plug and play or am i gonna need to change a bunch of ish around ?! i need help any would be appreciated =/ thanks .
Re: b16 in eg9 ?
U need OBD1 injectors, OBD1 IAT sensor, and an OBD1 DOHC Vtec dizzy would make things easyer too. Everything else will plug and play - some of the purge valves.
Re: b16 in eg9 ?
just use the obd2 gsr harness...it'll work
if u still have the secondary butterfly and running a stock ecu with knock sensor then you'll have to repin your shock tower and ecu, there's a DIY in the FAQ section..
Contender25
08-16-2007 07:14 PM
Jason703Racing
03-28-2006 07:13 PM
