b16 need help
b16 need help
hey guys i need help my car wont start no more im not gettin spark or fuel... but i already check all my fuses.... change my main relay.... change mu fuel pump... n my coilpack.... what else could it be
Re: b16 need help
have you messed with it recently, like a new anti theft system or with ur ecu, and you say your plugs arent firing? bc if so then your just not gettin fuel, which cld be clogged injectors or the fuel pump, or the line from the tank
Re: b16 need help
are you sure the pump you put in is good? and fuel lines, you visually inspect and feel them, make sure nothing obvious like torn or hard or brittle, rusted or leaking
Re: b16 need help
try spraying starter fluid into the intake then try to start it. If it turns over for a few seconds then dies then its more than likely a fuel problem. Does the fuel pump prime in the on position? Check to see if your fuel filter is clogged as well as injectors to see if they are clogged. If your getting fuel but no spark, swap the distributor and check your plug wires.
Re: b16 need help
if you havent changed your plugs, i would do that as well. Also, there is some way you can check if your getting spark to your plugs. I have seen it before, my buddy did it with a screwdriver and you could see a spark in between the screwdriver, im sorry i cant tell you exactly how to do it but im sure someone else knows what im talking about.
Re: b16 need help
jerryscherry
13
05-08-2014 10:08 PM
4doorcivic9
06-11-2008 06:31 AM
office888
03-18-2007 07:28 PM
Cameron60
01-16-2007 06:04 PM
