EGG in the RADIATOR????!!
Old 12-10-2009, 07:01 AM
MonKK's Avatar
Default EGG in the RADIATOR????!!
Ok, My car been running good for a couple of days, and yesterday is was like -2 degrees and in the morning when I try to start the car, it wouldn't start, Figure it was tooo cold. So I waited till it got warmer and after 2 or 3 times, it start. I drove it around for a bit and notice there is coolant leak around by my water pump and alternator. Now, I was told to crack an egg and add pepper, and then dump it in the radiator, then run it for 10-20 min. then drain it and replace wit new coolant. Anyone ever try this before? I knw it's on myth buster, but I just want to be safe on this. thanks.
Old 12-10-2009, 07:11 AM
alphalanos's Avatar
Default Re: EGG in the RADIATOR????!!
wat. find the leak and fix it maybe?
Old 12-10-2009, 07:14 AM
Ferio4ya's Avatar
fix the leak hahha i saw that episode as well and only do this if its a last resort!!! hahahhahaha!
Old 12-10-2009, 07:24 AM
itsnotfast's Avatar
Wow... Haha I would stick to conventional ways of repairing a coolant leak.
MonKK's Avatar
Well, it's freaking cold here and I have no garage. And not money right now to fix it. And I need to the car to drive to work and stuff. So I was just asking as a temporary fix. Think this will work though?
Old 12-10-2009, 07:29 AM
8VEYBEYB's Avatar
if you love yourself you'll do it. I wanna see the result
itsnotfast's Avatar
I've never heard of it but Ferio confirmed it can work. I guess you could try it but I would think the egg would just bake into your water pump and clog up your thermostat. What is the pepper for.. that special spice for your car?
Old 12-10-2009, 07:34 AM
Ferio4ya's Avatar
lol yeah the pepper doesnt make sense!!
on mythbuster it worked. they punctured a HOLE into the rad about the size of a normal screw driver, ran the car and of course a steady stream leak shooting through the hole, they cracked open ONE egg, dropped the yoke and egg white into the rad, and seconds! later the leaked completely stopped lol!!
but i would only do this as a last resort, meaning i stuck in the middle of BFE and i just went grocery shopping an have a dozen eggs on hand haha!!
Old 12-10-2009, 07:37 AM
itsnotfast's Avatar
Lol it really can't be good for your cooling system. Imagine what it going to do to the heater core, rad fins, thermostat, and the water pump.
batallic's Avatar
when was the last time the water pump has been changed
Old 12-10-2009, 07:45 AM
MonKK's Avatar
2 months ago! hm, LOL, I don't knw then. GAH, I think it only work if there is leaks in the radiator. But yet again, I don't knw.
Old 12-10-2009, 07:49 AM
CivicSpoon's Avatar
The egg trick is for a hole in the radiator, not a leak somewhere else in the system. I doubt an egg would even make it all the way to the water pump or water pump side of the engine; it'd be cooked and solidified before it reached there. You could try that Stop Leak stuff, but that stuff is horrible.
Old 12-10-2009, 07:56 AM
Dkober101's Avatar
http://www.amazon.com/CRC-401211-Hea.../dp/B000M8Q16M
OP: this has to be a joke right?
Old 12-10-2009, 07:58 AM
itsnotfast's Avatar
Stop leak is horrible for the entire cooling system. I wouldn't use it.
Old 12-10-2009, 07:59 AM
B16aEk4drbeater's Avatar
It's freakin $33 shipped for a new rad on ebay, are you guys serious????
Old 12-10-2009, 08:03 AM
Dkober101's Avatar
I dont think its just the radiator, or in fact the radiator at all.
Old 12-10-2009, 08:35 AM
New User
anisplas's Avatar
oh! this is first time I heard about this...
Old 12-10-2009, 08:59 AM
D Griff's Avatar
Myth busters is great. Everything they say should be trusted.
Old 12-10-2009, 09:13 AM
batallic's Avatar
the egg trick is only for the radiator itself, and its a quick fix like if u need to get home
Old 12-10-2009, 09:25 AM
supra-n-civic's Avatar
the eg is used as a bonding agent and the pepper is is hopes to bridge teh hole and give the egg something to bind to. in theory that is. it works but tis messy and not very good a technique. just fix it lagitimatly. like if its a hose try to trim the ends and re clamp it. if its the rad use solder and a heat sorce.
Old 12-10-2009, 09:51 AM
supersize's Avatar
do it, do it now.. post video... just do it, i mean whats the worst that can happen
Old 12-10-2009, 02:58 PM
Snazzy95eg8's Avatar
i had a pin hole in the koyo radiator i had in my 240sx and i did that and it worked fine idk about the pepper tho. ive never heard of that but i would try a legit product first from like an autozone and use the egg as a last resort
Old 12-10-2009, 03:18 PM
joelmatt89's Avatar
what engine is this I have been told that the d series tend to like just salt with their eggs, while the b series go for both salt and pepper, h like pepper, and yeah you guessed it k series there just so badass they down em plain no yolk or anything just the white.
Seriously this is retarded you'll end up costing yourself more money.
Old 12-10-2009, 03:26 PM
layedoutat0psi's Avatar
i had a friend with a older subaru once that had a hole in his coolant system. he heard of the egg thing and decided to try it out and it worked
Old 12-10-2009, 09:50 PM
thumper64's Avatar
if it's the water pump, it's probably defective. If it's the rad, get a different one or solder it.
Quick Reply: EGG in the RADIATOR????!!
