rear disk brake conversion questions please help...
ok i got a 1993 honda civic cx and want to do a 1996 integra rear disk brake conversion. my question is i already got almost the complete the whole rear conversion but missing the parts where i circle in red. will i be needing those too or do will my stock rear drum setup already have those arms? also will i be needing integra e-brake cable and integra rear brake lines also since the rear conversion i got did not come with them?
Re: rear disk brake conversion questions please help...
yes ur drum set up will have that. and yes u will need teg or civic with rear disk ebrake calbes and brake lines. its a easy swap.
GL bro
yes you do already have those pieces on your drum set-up and they are usable however you cant just buy any teg or civic with rear disc brake lines.. you'll need the SI hatch ebrake lines considering your car is a hatch the coupe and sedan civic ebrake lines wont work and the integra ones might but i would just go with the SI with rear disc e brake cables
GL bro
GL bro
GL bro
GL bro
You could get aftermarket ones: Skunk2,Buddy Club,Etc..That way you can adjust your rear camber settings too.
Just a thought.
Just a thought.
PHANTOM MENACE
...however you cant just buy any teg or civic with rear disc brake lines.. you'll need the SI hatch ebrake lines considering your car is a hatch the coupe and sedan civic ebrake lines wont work and the integra ones might but i would just go with the SI with rear disc e brake cables
GL bro
GL bro
Exactly why won't the coupe/sedan ebrake lines work? And why "might" the integra one work?
the integra one will work man and so would a coupe i am pretty ****ing sure, mine has integra lines on it
optoomistic
03-22-2005 11:43 AM
