overheat alarm
overheat alarm
I don't know if this has ever happened to anyone else but you're driving along, look down and your coolant temp gauge is way up, then shortly thereafter you're replacing a headgasket, engine, vehicle etc. etc.
Has happened to me at least 3 times over the years. I don't tend to drive with my eyes glued to my gauge cluster.
I was looking on the web and couldn't find any good info for an audible/adjustable coolant temp alarm gauge/system/add-on that can eliminate this type of incident.
Any info or ideas on where to purchase or how to build such an audible coolant temp alarm system?
Re: overheat alarm
one could probably tap into the wiring and if skilled with simple electronics, wire up a series of resistors, leds, and a buzzer. i don't know specifically, but i'm curious too.
bumpweasel has occurred.
Re: overheat alarm
google told me about this. http://www.enginewatchdog.com/tm2.html which means it probably requires more then any one of us may be able to come up with as a cheaper solution. less you find a buzzer that only responds to 12V and a very nitpickey temp sensor.
Re: overheat alarm
Re: overheat alarm
I'm in the process of replacing my engine with a remanufactured, and rather than replace ~12 coolant hoses I'd rather buy the 3 that made crackling/tearing noises when I removed them (I'm suspicious about) and spend the rest of the money on a warning system.
94 Hatchback Si
Audio / Security / Video
03-08-2009 10:52 AM
Tinkerbell_too
01-27-2009 07:27 PM
