b16a idle prob...
b16a idle prob...
its an jdm eg9 b16a ob1 ,
issue car sometimes idle at low rpms like 500, 400 even sometimes at 200 or less. at times when turn the steering wheel at idle at a car park etc it will cut off...
i am thinking its the iacv??? if so how to clean/service it... any guidelines ,or other discussed forums... thanks
Re: b16a idle prob...
just remove it and spray some carb cleaner in there. let it dry off and repeat if you are not satisfied. another thing is check your fitv, the screw might have came loose. last thing is your tps may cause idle fluctuations.
