Honda OEM Bolts
Honda OEM Bolts
Anyone know where to get honda OEM bolts for cheap? i need all three LCA bolts for each side and they are 7.50 a bolt from honda. thats $45 for bolts....
Re: Honda OEM Bolts
go to a junk yard for them. $7.50 each is cheap!! from the dealer. i went to get the hanger bolts for a fuel tank..it was $28.00 for each bolt and $2.00 each for the nut!! we grabbed them at the junk yard for $5.00 and the tank was already off the cars we looked at. actually i got 4 total for $10.00. i wanted spares
Re: Honda OEM Bolts
ever try removing LCA bolts? they are horrible at home with torches and impact let alone in a junk yard. i might go OEM....brand new for a rebuild.....https://honda-tech.com/forums/appearance-build-threads-122/my-ej1-build-boosted-ls-coupe-2318659/
Re: Honda OEM Bolts
ever try removing LCA bolts? they are horrible at home with torches and impact let alone in a junk yard. i might go OEM....brand new for a rebuild.....https://honda-tech.com/forums/showthread.php?t=2318659
Re: Honda OEM Bolts
True, that actually doesnt seem that bad, when you compare that to how much the charge for a freaking plastic clip
Maybe you can talk to them and get a discount for ordering alot?
Re: Honda OEM Bolts
well i see it like this.....i replaced/am replacing the entire *** end of the car basically why put old rusted bolts back in there? the rest of the bolts in my rear disc swap i purchased brand new from honda...i guess i better do the same with the LCA bolts lol
Re: Honda OEM Bolts
oem nuts/bolts in a package differ from ones off a car how? i know im a tad cheap, but there's no way i would pay $50 for something i could get from a local junkyard for ~$5 including entrance fee and gas
Re: Honda OEM Bolts
I have a few bolts laying around after I did my rear disc conversion last week. I will see exactly what I have when I get home, but if you want them, just pay for shipping and I'll send them to you. I know for sure I have the bolts that hold the lca to the trailing arm, but not sure what else. LMK.
Technical Hero
Re: Honda OEM Bolts
X2, if you were really worried you could get these in grade 8 or better and they'll be just as reliable as oem. whatever you do put some anti-seize on the new ones so you won't have a similar problem again.
Re: Honda OEM Bolts
Junk yard or hardware store and if your really complaining about the price for OEM and argue you want to use OEM bolts them why bother making thread geeeZ. Take your bolts to the nearest harware store and match it up . . . dotn worry your 2000HP honda wont break it loose if u do it right. Thread lock the b!tch so you feel safer haha.
